legend fonts issue
amol
legend fonts issue
Post by amol » Tue Jan 24, 2017 1:44 pm
Hi Steema,
We have a query regarding the "legend fonts are changed when we change the bottom axis fonts settings".
For your reference we are sending the demo application.
We are defining the whole scenario in below:-
• Run the demo application.
• Double click on chart the chart editor is opened.
• In chart editor we open the legend tab→Position→Check and then Uncheck the custom position check box.
• Now go to Axis tab→select bottom axis→labels→Text→then click on Font button and then do some settings in font dialog and click on Ok button then we can see the same fonts settings is applied on legend fonts which we applied on bottom axis labels.
So please kindly guide us how we prevent the font settings on legends while applied font settings on Bottom axis.
Thanks & regards
Plano Research
TreeDemo.7z
(116.66 KiB) Downloaded 780 times
Re: legend fonts issue
Post by Christopher » Wed Jan 25, 2017 10:52 am
As you can see here:
https://www.screencast.com/t/o6ezz5QAw
I am not able to reproduce this problem with the latest TeeChart.dll. I see you are using version 4.1.2012.5103, which is now nearly five years old. Have you tried downloading the latest evalution version and testing if the code you can see in my video works for you?
