I am upgrading my VB6 application from TeeChart V8.0.0.5 to TeeChart 2016.0.0.2 due to printing problems in Version 8 and Windows 10. Since upgrading to TeeChart 2016 my print issues have been corrected but now my polar plots will not display the correct data. See attached pictures showing the polar plot for TeeChart 8 and polar plots for TeeChart 2016.
With TeeChart 8, I used AddArray to add the data to the Series. With TeeChart 2016 first picture I used AddArray and second picture I have tried Add Polar and still cannot get the correct plot.
Issue with Polar Chart
- TeeChart 2016 using AddPolar
- TeeChart 2016 - polar using addploar.png (171.21 KiB) Viewed 12219 times
- TeeChart 2016.0.0.2
- TeeChart 2016 - polar.png (149.04 KiB) Viewed 12219 times
- TeeChart V8.0.0.5
- TeeChart8 - polar.png (90.32 KiB) Viewed 12219 times
Re: Issue with Polar Chart
I've just made a simple example with TeeChart ActiveX v2016.0.0.2 and this code:
And I get the same result you were getting with TeeChart ActiveX v8:
So I'm not sure to understand how are you exactly adding those points. If you still find problems with it, please try to arrange a simple example project we can run as-is to reproduce the problem here.
TChart1.Header.Text.Clear
TChart1.Aspect.View3D = False
TChart1.Legend.Hide
TChart1.AddSeries scPolar
With TChart1.Series(0).asPolar
.Pointer.Visible = False
.CircleBrush.Style = bsClear
.Brush.Style = bsClear
.Pen.Color = TChart1.Series(0).Color
.RotationAngle = 90
.AddPolar -176, -14.683, "", clTeeColor
.AddPolar -171, -7.123, "", clTeeColor
.AddPolar -166, -7.386, "", clTeeColor
.AddPolar -161, -7.409, "", clTeeColor
.AddPolar -156, -7.831, "", clTeeColor
.AddPolar -151, -7.624, "", clTeeColor
.AddPolar -146, -12.116, "", clTeeColor
.AddPolar -141, -16.562, "", clTeeColor
.AddPolar -136, -17.006, "", clTeeColor
.AddPolar -131, -21.822, "", clTeeColor
.AddPolar -126, -20.759, "", clTeeColor
.AddPolar -121, -24.894, "", clTeeColor
.AddPolar -116, -22.416, "", clTeeColor
.AddPolar -111, -33.226, "", clTeeColor
.AddPolar -106, -33.623, "", clTeeColor
.AddPolar -101, -28.852, "", clTeeColor
.AddPolar -96, -25.223, "", clTeeColor
.AddPolar -91, -23.405, "", clTeeColor
.AddPolar -86, -23.168, "", clTeeColor
.AddPolar -81, -27.575, "", clTeeColor
.AddPolar -76, -29.608, "", clTeeColor
.AddPolar -71, -25.718, "", clTeeColor
.AddPolar -66, -32.794, "", clTeeColor
.AddPolar -61, -23.667, "", clTeeColor
.AddPolar -56, -22.978, "", clTeeColor
.AddPolar -51, -23.77, "", clTeeColor
.AddPolar -46, -25.691, "", clTeeColor
.AddPolar -41, -26.886, "", clTeeColor
.AddPolar -36, -21.122, "", clTeeColor
.AddPolar -31, -20.086, "", clTeeColor
.AddPolar -26, -17.813, "", clTeeColor
.AddPolar -21, -13.13, "", clTeeColor
.AddPolar -16, -13.267, "", clTeeColor
.AddPolar -11, -13.065, "", clTeeColor
.AddPolar -6, -5.737, "", clTeeColor
.AddPolar -1, 28.65, "", clTeeColor
.AddPolar 4, -1.07, "", clTeeColor
.AddPolar 9, -13.488, "", clTeeColor
.AddPolar 14, -5.515, "", clTeeColor
.AddPolar 19, -18.006, "", clTeeColor
.AddPolar 24, -18.737, "", clTeeColor
.AddPolar 29, -21.368, "", clTeeColor
.AddPolar 34, -27.901, "", clTeeColor
End With
I think I found why my data looked was wrong. Under Series General Tab, my data was sorted. How do I set the sort to None?
- Series - General Tab
- Series General tab.png (22.24 KiB) Viewed 12187 times
You can try with this:
If you still find problems with it, try to arrange a simple example project we can run as-is to reproduce the problem here.
TChart1.Series(0).XValues.Order = loNone
Thank you that worked
