Drag Functionality
swappyk
Drag Functionality
Post by swappyk » Mon Oct 03, 2016 5:54 pm
I know TeeChart allows DragPoint functionality where we can move points, was wondering if we have functionality to move the entire series if a point is dragged, adjust the other data points once a data point is moved.
Re: Drag Functionality
Post by Yeray » Tue Oct 04, 2016 8:25 am
You could do this manually using events instead of using the DragPoint tool. Ie:
	private static void dragTest() {
		tChart1.getHeader().setVisible(false);
		tChart1.getZoom().setAllow(false);
		Points points1 = new Points(tChart1.getChart());
		points1.fillSampleValues(10);
		tChart1.getAxes().getBottom().setMinMax(points1.getMinXValue(), points1.getMaxXValue());
		tChart1.getAxes().getLeft().setMinMax(points1.getMinYValue(), points1.getMaxYValue());
		tChart1.addMouseMotionListener(new MouseMotionAdapter() {
			@Override
			public void mouseMoved(MouseEvent e) {
				if (draggingSeries != null)
					tChart1.setCursor(Cursor.HAND);
				else {
					int tmpIndex = -1;
					for (int t = 0; t < tChart1.getSeriesCount(); t++) {
						Series s = tChart1.getSeries(t);
						if (s.getActive()) {
							tmpIndex = s.clicked(e.getX(), e.getY());
					if (tmpIndex > -1)
						tChart1.setCursor(Cursor.DEFAULT);
			@Override
			public void mouseDragged(MouseEvent e) {
				if ((draggingSeries != null) && (draggingIndex != -1)) {
					double diffX = draggingSeries.getHorizAxis().calcPosPoint(e.getX())
							- draggingSeries.getHorizAxis().calcPosPoint(OldXPos);
					double diffY = draggingSeries.getVertAxis().calcPosPoint(e.getY())
							- draggingSeries.getVertAxis().calcPosPoint(OldYPos);
					for (int i = 0; i < draggingSeries.getCount(); i++) {
						draggingSeries.getXValues().setValue(i, draggingSeries.getXValues().getValue(i) + diffX);
						draggingSeries.getYValues().setValue(i, draggingSeries.getYValues().getValue(i) + diffY);
					OldXPos = e.getX();
					OldYPos = e.getY();
				tChart1.refreshControl();
		tChart1.addMouseListener(new MouseAdapter() {
			@Override
			public void mousePressed(MouseEvent e) {
						draggingIndex = s.clicked(e.getX(), e.getY());
						if (draggingIndex != -1) {
							draggingSeries = s;
							OldXPos = e.getX();
							OldYPos = e.getY();
							break;
			@Override
			public void mouseReleased(MouseEvent e) {
				draggingSeries = null;
				draggingIndex = -1;
