TeeChart Legend
Sharpenski
TeeChart Legend
Post by Sharpenski » Tue Sep 20, 2016 1:25 pm
Is there a means of allowing the user to drag and resize the legend for a chart?
Re: TeeChart Legend
Post by Yeray » Wed Sep 21, 2016 9:37 am
You can do it manually using the mouse events. Ie:
uses Series;
var legendDragging: Boolean;
    oldPos: TPoint;
  Chart1.View3D:=false;
  Chart1.AddSeries(TBarSeries).FillSampleValues();
  legendDragging:=false;
  if Chart1.Legend.Clicked(X, Y)>-1 then
    legendDragging:=True;
    oldPos:=Point(X,Y);
  legendDragging:=False;
  Y: Integer);
    Chart1.Cursor:=crHandPoint;
  if legendDragging then
    Chart1.Legend.CustomPosition:=true;
    Chart1.Legend.Left:=Chart1.Legend.Left+(X-oldPos.X);
    Chart1.Legend.Top:=Chart1.Legend.Top+(Y-oldPos.Y);
    oldPos:=Point(X,Y);
