control TChartSeries hover effect manually
niotronic
Post by niotronic » Mon Sep 12, 2016 4:19 pm
I would like to enable/disable the hovering for the whole TLineSeries manually, for example enable it in the OnClick event of a series in order to highlight some series - is there a way to do that ?
Best regards,
Klaus
Re: control TChartSeries hover effect manually
Post by Yeray » Tue Sep 13, 2016 7:50 am
Hi Klaus,
Do you mean doing something like this?
uses Series;
  Chart1.View3D:=false;
  with Chart1.AddSeries(TLineSeries) do
    FillSampleValues();
    OnClick:=SeriesClick;
  Chart1.Hover.Visible:=false;
procedure TForm1.SeriesClick(Sender:TChartSeries; ValueIndex:Integer; Button:TMouseButton; Shift: TShiftState;
                          X, Y: Integer);
  if Sender.Pen.Width=1 then
    Sender.Pen.Width:=3
    Sender.Pen.Width:=1;
niotronic
Post by niotronic » Tue Sep 13, 2016 10:20 am
Dear Yeray,
thanks for the suggestion to change the pen width in the onclick event ! This is an option but does not a have similar look when compared with hovering. Is there a way to make it look like the hover effect ? - Can I turn on/off the hovering manually at runtime for the whole series - i.e. show the hover effect for all connecing lines, and not only the selected element like its standard behaviour when Chart1.Hover.Visible:=TRUE ?
Best regards,
Klaus
Post by Yeray » Wed Sep 14, 2016 11:01 am
You can assign the pen and color to the whole series at the OnClick eventif you want. Ie:
uses Series, TeCanvas;
var oldPen: TTeePen;
    FillSampleValues();
  oldPen:=TTeePen.Create(nil);
                          X, Y: Integer);
    oldPen.Assign(Sender.Pen);
    oldPen.Color:=Sender.Color;
    Sender.Pen.Assign(Chart1.Hover.Pen);
    Sender.Color:=Chart1.Hover.Pen.Color;
  end
    Sender.Pen.Assign(oldPen);
    Sender.Color:=oldPen.Color;
