change color of labels in circular gauge
Cozmos
Post by Cozmos » Wed Sep 07, 2016 1:27 pm
I'm creating a circular gauge in Xamarin forms, and I'm trying to change the label's color. I tried setting every property I could find, but it won't change... Can anyone help me?
this is my code: (just setting the property of the axis labels color here, because that's the one I think needs to be set... I also tried it with many other properties I found, but none are working).
	Chart CreateView ()
			var c = new Chart (this);
			c.Header.Visible = false;
			c.Panel.Visible = false;
			var gauge = new CustomChart (c.Chart);
			gauge.Frame.Visible = false;
			gauge.FaceBrush.Visible = false;
			gauge.DisplayTotalAngle = 180;
			gauge.TotalAngle = 180;
			gauge.Value = GetCurrentValue ();
			gauge.Ticks.Visible = false;
			gauge.Minimum = 0;
			gauge.Maximum = GetMonths ();
			gauge.Axis.Increment = GetMonths () / 4;
			gauge.RedLine.Visible = false;
			gauge.GreenLineStartValue = 0;
			gauge.GreenLineEndValue = GetMonths ();
			gauge.GreenLine.Gradient.Direction = Steema.TeeChart.Drawing.GradientDirection.LeftRight;
			gauge.GreenLine.Gradient.StartColor = Color.FromRgb (6, 64, 137);
			gauge.GreenLine.Gradient.EndColor = Color.FromHex ("#159DFB");
			gauge.GreenLine.Pen.Visible = true;
			gauge.Axis.Labels.Color = Color.Red;
			return c;
In attachment the screenshot of my gauge, I want to change the color of the numbers on the axis
Thanks!
Screen Shot 2016-09-07 at 15.26.10.png (28.68 KiB) Viewed 25465 times
Re: change color of labels in circular gauge
Post by Christopher » Wed Sep 07, 2016 3:37 pm
Rather than Labels.Color, which is the color of the shape around the label (the shape is invisible by default), you should change the Label.Font characteristics, e.g.
gauge.Axis.Labels.Font.Color = Color.Red;
Cozmos
Post by Cozmos » Thu Sep 08, 2016 9:50 am
I tried that too, and it isn't working either...
Post by Christopher » Thu Sep 08, 2016 10:36 am
The following code works as expected with TeeChart.dll, the Windows Forms version:
      Func<int> GetCurrentValue = () =>
        return 40;
      Func<int> GetMonths = () =>
        return 80;
      CircularGauge gauge = new CircularGauge(tChart1.Chart);
      gauge.Value = GetCurrentValue();
      gauge.Minimum = 0;
      gauge.Maximum = GetMonths();
      gauge.Axis.Increment = GetMonths() / 4;
      gauge.GreenLineEndValue = GetMonths();
      gauge.GreenLine.Gradient.Direction = LinearGradientMode.ForwardDiagonal;
      gauge.GreenLine.Gradient.StartColor = Color.FromArgb(255, 6, 64, 137);
      gauge.GreenLine.Gradient.EndColor = Utils.HexToColor("FF159DFB");
gives me this:
Which version of TeeChart are you using?
Cozmos
Post by Cozmos » Thu Sep 08, 2016 10:50 am
I'm using the Xamarin Forms version: TeeChartXamarinFormsSource-4.0.2016.05310-osx (the newest release)
I tried it with your code, but still no success.
Post by Pep » Thu Sep 08, 2016 4:26 pm
it's strange, I've just tested it here with the same version and it's working fine using :
gauge.Axis.Labels.Font.Color = Color.Blue;
or with another color.
Does this happens on both iOS and Android ?
