versionnr/unregistered
Jack@007
Post by Jack@007 » Tue Jun 14, 2016 6:19 pm
Just updated from 2016.0.0.0 to 2016.0.0.1 (AX 32 bit).
When calling :AboutBox() both versions display the same version (v2016.0.0.0.160422 32 bit ActiveX).
Besides why is it saying "unregistered" in the bottom left side?
Greetings,
Jack
Re: versionnr/unregistered
Post by Yeray » Wed Jun 15, 2016 8:47 am
Hi Jack,
Jack@007 wrote: Just updated from 2016.0.0.0 to 2016.0.0.1 (AX 32 bit).
Sorry, we missed to update the internal constant to reflect the new version number in that release.
Jack@007 wrote:Besides why is it saying "unregistered" in the bottom left side?
We'll revise what's wrong here. Anyhow worth to note this doesn't limit your product in any manner.
Jack@007
Post by Jack@007 » Thu Jun 23, 2016 5:23 pm
Updated to 2016.0.0.2: Still "unregistered" !!!!!
Post by Yeray » Tue Jun 28, 2016 8:40 am
That's strange. We've checked it here in 3 different machines and it works fine with v2016.0.0.2.
Maybe the installer was run without enough privileges to write the necessary key into the registry. To check that, I would suggest you to uninstall the v2016.0.0.2 and reinstall it making sure you run the installer "as administrator".
You should find a key in the registry here (don't write it here, it should be your license number):
HKEY_CURRENT_USER\SOFTWARE\Steema Software\Licenses\AX\2016.0.0.2
Jack@007
Post by Jack@007 » Tue Jun 28, 2016 5:11 pm
I work a little bit different.
When a new version of Teechart comes out I use an old, secure computer to run the installer. I pick up the new "teechart2016.ocx" and distribute this to the computers who need it. The registry key is therefore never present.
How do you imagine to distribute Teechart on a few dozen (or more) computers?
Besides, if I were to run a commercial enterprise and distribute teechart with one of my applications wouldn't that reveal my licence number to a buyer?
Greetings,
Jack
Post by Yeray » Wed Jun 29, 2016 9:42 am
Hi Jack,
The About form (like the editor) isn't designed to be presented to the final user.
