TeeChartVCLFMXSOURCE-2016.18
Need some help please.
I have 4 IDE's installed XE2, XE7, Seattle & Berlin.
When running TeeRecompile all compile ok except for XE2 which fails with the error message " Required package "IndyProtocols not found" because of the version of Indy installed.
If I then change all relevant XE2 DPK's in the source folder to use IndyProtocols916 it then fails with the error message "Required package 'IndyProtocols916' not found".
But these do exists. Can you please tell me where TeeRecompile is looking for these?
Also are there any instructions on how to do this manually?
Bruce
Using TeeRecompile
Re: Using TeeRecompile
Sorry. I of course meant IndyProtocols160!
Hi Bruce,
TeeRecompile calls the IDE compiler but it probably doesn't find your Indy installation path.
To manually recompile the TeeChart packages, you can try to build open the .groupproj attached and build all the packages (with the corrected references). Then you should be able to install the Dcl* packages into your IDE.
- Tee9RADXE2.zip
- (956 Bytes) Downloaded 818 times
Thanks. I get so far but
doesn't compile. I get the error message: [DCC Error] VCLTee.TeCanvas.pas(5588): E2010 Incompatible types: 'TeCanvas.TTeeCanvas' and 'VCLTee.TeCanvas.TTeeCanvas'
Procedure TTeeCanvas.TextOut(const X,Y:TCoordinate; const Text:String; AllowHtml:Boolean);
if AllowHtml then
HtmlTextOut(Self,{$IFDEF FMX}Round{$ENDIF}(X),{$IFDEF FMX}Round{$ENDIF}(Y),Text)
TextOut(X,Y,Text);
Hello Bruce,
Sounds as a problem with the prefixes. Have you tried adding "VCLTee" to the "unit scope names"?
I was still using XE2 for just a couple of legacy projects that were using components that I do not have the source for and are now no longer available.
I decided to use other components instead and am now using 10.1 Berlin so the problem has gone away.
Thanks for your help.
Bruce
Bruce
