export data with datetime axis
bahmed
Post by bahmed » Tue Dec 16, 2003 9:26 pm
I am trying to export data from an activeX teeChart using "Editor dialog".
The x-axis is in "datetime" format but the exported data shows "floating point" vlaues for X-axis (as shown below).
----- code for pupulating the series -----
MyChart.Axis.Bottom.Labels.DateTimeFormat="MM/dd/yy hh:mm:ss";
MyChart.Axis.Bottom.AutomaticMaximum=false;
MyChart.Axis.Bottom.Maximum = dblStopTime;
MyChart.Axis.Bottom.AutomaticMinimum=false;
MyChart.Axis.Bottom.Minimum = dblStartTime;
/* rs is a recordset with two field v1 and v2 in it */
MyChart.Series(0).DataSource=rs;
MyChart.Series(0).XValues.ValueSource="v1";
MyChart.Series(0).YValues.ValueSource="v2";
// if I add following lines then I can get the datetime to
// show up in the export, but "floating point value" of the
// time still shows up in the exported .txt data
//MyChart.Series(0).LabelsSource = "v1";
//MyChart.Axis.Bottom.Labels.Style= TeeChart.EAxisLabelStyle.talValue;
------------- output of the data export-------
0 37965 45.1049118041992
1 37965.0034722222 44.8395805358887
2 37965.0069444444 44.7511405944824
3 37965.0104166667 44.4858207702637
4 37965.0138888889 44.3973808288574
5 37965.0173611111 43.9551696777344
6 37965.0208333333 43.8667297363281
7 37965.0243055556 43.6898498535156
8 37965.0277777778 43.5129585266113
---------- output with the extra two lines ---------
0 12/10/2003 37965 2.47999954223633
1 12/10/2003 12:05:00 AM 37965.0034722222 2.47999954223633
2 12/10/2003 12:10:00 AM 37965.0069444444 2.45166778564453
3 12/10/2003 12:15:00 AM 37965.0104166667 2.44166946411133
4 12/10/2003 12:20:00 AM 37965.0138888889 2.44166946411133
5 12/10/2003 12:25:00 AM 37965.0173611111 2.375
Post by Pep » Wed Dec 17, 2003 12:37 pm
Have you set the XValues of the Series to DateTime ?
MyChart.Series(0).XValues.DateTime = True
Josep Lluis Jorge
http://support.steema.com
bahmed
Post by bahmed » Wed Dec 17, 2003 3:21 pm
Yes I set the DateTime property to true (which was not shown in the code segment). The problem is not in the display of the chart (or graph) but in exporting the data to a txt file using TeeChart Editor dialog's Export-> Data -> (Format: txt) & (Include: Point Index, Point Label)...
I want to export the time in "actual date time" not in floating point value
Look at the exported text data: the second column is souposed to be date-time.
0 37965.0000000000 45.1049118041992
Post by Pep » Thu Dec 18, 2003 9:04 am
Which TeeChart version are you using ?
It works fine here using the latest TeeChart Pro v6.04. I've attached one example to the steema.public.attachments newsgroup, could you please test it if works fine for you ?
Josep Lluis Jorge
bahmed
Post by bahmed » Fri Dec 19, 2003 7:16 pm
I am using version 5.0.5.0
Here is the result of the attachement running with TeeChart 5.
XSeries0
Post by Pep » Mon Dec 22, 2003 10:42 am
Yes, you're correct, I'm able to reproduce the problem here using the TeeChart Pro v5.05. This problem has been solved in the TeeChart Pro v6.0.
Josep Lluis Jorge
