TeeChart Pro D7 - Legeng color
Torez
Post by Torez » Wed May 04, 2016 3:59 am
Hallo all,
I just got registered version of TeeChart Pro for D7. And I am facing two problems after installation
'About' field shows : TRIAL version ( but all works normally, not big deal, but I would still prefer to
see Registered).
Second problem is color of 'Series Names' in Legend. 'Font Series Color' in TAB 'Style' is activated, but
color shown in run time is from TAB 'Format/Font'/Font'. I have this issue only after Registered version was
installed. Demo was working perfectly fine.
Now my whole project is delayed due to this problem. Can you advise how to fix it ?
Thank you
Torez
Torez
Re: TeeChart Pro D7 - Legeng color
Post by Torez » Wed May 04, 2016 4:17 am
Just to clarify, series are FastLine.
Post by Yeray » Wed May 04, 2016 1:28 pm
It seems to work fine for me with both v2015.16 and the latest v2016.17. What version are you using?
If you still find problems with it, could you please arrange a simple example project we can run as-is to reproduce the problem here?
Torez
Post by Torez » Thu May 05, 2016 1:14 am
Hallo Yeray,
I have installed TeeChart2015Delphi7 / January 23, 2015 / Build 2015.14.150120 as it was one file dedicated for D7 only.
After you pointed out, that higher versions works well, I just reinstalled it.
Thank you for answer
Tomas
Post by Yeray » Thu May 05, 2016 7:12 am
I'm glad to hear it works fine for you with the latest version.
