Text block chart
Softdrill NL
Text block chart
Post by Softdrill NL » Tue Apr 19, 2016 12:48 pm
I am trying to achieve a chart output similar to format shown below (hand-drawn to give you an idea).
Sample chart.jpg (44.06 KiB) Viewed 5747 times
The general idea is that the left (inverted) axis relates to a depth. I am trying to plot comment boxes that relate to specific depths / depth ranges. I have tried TAnnotationTool, TRectangleTool and a ShapeSeries. When the chart is zoomed/scrolled the text boxes must be scaled / displayed accordingly.
So far the ShapeSeries appears to give the best result, but unfortunately HTML text output is not supported. Do you have any ideas / recommendations how to achieve such a chart? I am a relative newbie, so some guides is likely to save me a lot of time!
Thanks in advance. Regards,
Mark
Re: Text block chart
Post by Yeray » Wed Apr 20, 2016 12:39 pm
Hi Mark,
You could try doing something like this:
uses TeeShape;
type
  TMyRectShape = class(TChartShape)
  private
    Shape: TTextShape;
  protected
    procedure DrawValue(ValueIndex:Integer); override;
  public
   Constructor Create(AOwner : TComponent); override;
type
  TShapeAccess=class(TCustomTextShape);
Constructor TMyRectShape.Create(AOwner : TComponent);
  inherited;
  Shape:=TTextShape.Create(ParentChart) as TTextShape;
  with Shape do
    TextFormat:=ttfHtml;
    AutoSize:=false;
    Brush.Clear;
procedure TMyRectShape.DrawValue(ValueIndex:Integer);
var tmpS      : String;
  tmpS:=Text.Text;
  Text.Clear;
  inherited;
  Text.Text:=tmpS;
  Shape.Text:=tmpS;
  Shape.ShapeBounds:=Bounds;
  TShapeAccess(Shape).CalcBounds(ParentChart);
  Shape.Draw;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TMyRectShape) as TMyRectShape do
    Style:=chasRectangle;
    Shape.ParentChart:=Chart1;
    Text.Add('<b>Hello</b>');
    Text.Add('<br><font color=GREEN size=8>This is a shape</font>');
    Text.Add('<br><font color=Blue size=15>with html text</font>');
    X0:=10;
    X1:=50;
    Y0:=20;
    Y1:=40;
  Chart1.Axes.Left.Grid.Visible:=false;
  Chart1.Axes.Left.Inverted:=true;
  Chart1.Axes.Left.SetMinMax(0,100);
  Chart1.Axes.Bottom.SetMinMax(0,100);
  Chart1.Axes.Bottom.Visible:=false;
