Convexhull function
Paola
Convexhull function
Post by Paola » Mon Jan 04, 2016 9:27 pm
Hi.
I want to use the function convexHull which calculates the boundary points of the convex hull of a set of 2D xy points.
I've been trying to use this function (I'm working with VB), but I can´t make it work. When I try to include it, VB does not recognize it.
I did not find anything in the example file, Do you have an example? How can I make it work? please.
Re: Convexhull function
Post by Christopher » Thu Jan 07, 2016 8:55 am
Hello Paola,
Apologies for the delay in this reply.
The clearest example of the use of the ConvexHull function within the TeeChart code itself is in the Perimeter function, an example of which is in the feature demo:
%PROGRAMFILES(x86)%\Steema Software\Steema TeeChart for .NET 2015 4.1.2015.12160\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe
All Features -> Welcome !\Functions\Extended\Perimeter
You can see its use in the source code using a .NET reflector, e.g.
Paola
Post by Paola » Fri Jan 08, 2016 3:53 pm
Thank you very much :)
