- Excel Scatter Chart Example
- Excel Scatter Chart.png (16.49 KiB) Viewed 8164 times
- TeeChart Scatter Chart 1
- Scatter Chart Error.png (24.45 KiB) Viewed 8161 times
- TeeChart Scatter Chart 2
- Scatter Chart.png (25.39 KiB) Viewed 8166 times
I think the code you need you should already have in the following method:Quant wrote:But we need to achieve the same programmatically at run time (instead of design time) by setting the axis relative position according to (0,0) coordinates.
private void InitializeComponent()
Hi Christopher,I think the code you need you should already have in the following method:
ColorLine vertiColorLine = new ColorLine(tChart1.Chart);
vertiColorLine.Axis = tChart1.Axes.Left;
vertiColorLine.Value = 0;
vertiColorLine.AllowDrag = false;
ColorLine horizColorLine = new ColorLine(tChart1.Chart);
horizColorLine.Axis = tChart1.Axes.Bottom;
horizColorLine.Value = 0;
horizColorLine.AllowDrag = false;
this.tChart1.Axes.Left.AxisPen.Visible = false;
this.tChart1.Axes.Left.MinorTicks.Visible = false;
this.tChart1.Axes.Left.Ticks.Visible = false;
this.tChart1.Axes.Bottom.AxisPen.Visible = false;
this.tChart1.Axes.Bottom.MinorTicks.Visible = false;
this.tChart1.Axes.Bottom.Ticks.Visible = false;
