Teechart Resizing Issue in Excel VBA Userform
Perecon
Post by Perecon » Thu Oct 01, 2015 6:34 am
I am constantly having issues with Teechart automatically resizing itself to a huge number (49151.25) The problem is usually happened when the chart container (in my case, a MS FORMS MultiPage) has been moved or resized. I suspect the chart was cropped a bit in the container. I tried to resize it back but sometimes it fails and the chart keep revert to 49151.25 (either width or height, depending on which side it is cropped).
Please let me know how to fix this issues. I'm using TeeChart Pro v2013.0.1.4.131120 32 bit ActiveX.
Re: Teechart Resizing Issue in Excel VBA Userform
Post by Yeray » Fri Oct 02, 2015 11:31 am
Could you please try to reproduce the problem in a simple example project we can run as-is here?
Also, have you tried with the latest version, v2015.0.0.3?
