Monochrome option and psDash interspace
cssesuc
Post by cssesuc » Fri Sep 25, 2015 1:00 pm
hi,
On a canvas, I set for the LeftAxis and BottomAxis axes, a Grid with psDash
BottomAxis.Grid.Style = psDash
If I print with Monochrome option, the grid appears as a straight line.
Can one control the interspace for the Dash, and if so which option shall I use here?
Many thanks for your valuable help
thanks,
Nabil Ghodbane (PhD. Habil)
Re: Monochrome option and psDash interspace
Post by Yeray » Mon Sep 28, 2015 2:10 pm
Hello Nabil,
I've made a simple example printing a chart to a virtual pdf printer and I can see the dashed style in the bottom axis grid.
Here the code:
uses Series, TeeEdiGene;
  Chart1.Monochrome:=true;
  ChartPreview(nil,Chart1);
  Chart1.Monochrome:=false;
  Chart1.Legend.Visible:=false;
  Chart1.AddSeries(TBarSeries).FillSampleValues;
  Chart1.Axes.Bottom.Grid.Style:=psDash;
And here the pdf I get:
Chart1.zip
(11.51 KiB) Downloaded 742 times
cssesuc
Post by cssesuc » Mon Sep 28, 2015 2:29 pm
hi Yeray,
many thanks for your reply.
I certainly did not describe accurately the issue I have to deal with here and which is illustrated on the attached plot on which I need to have a grid.
My point is to know whether one can control the dashes frequency aka the gap between two consecutive dashes of one grid line.
basically, can one go from:
_  _  _  _  _  _  _  _  _  _  _  _  _  _  _  _  _  _  _  _  _
to (a larger gap)
Is this supported at all? I had a careful look at the Grid properties, but did not come to any improvement.
Note that, the file is saved as WMF (If I use BMP, the plot quality is worse)
thanks!
thanks,
Post by Yeray » Wed Sep 30, 2015 3:04 pm
Then, this looks related to this feature request.
I'd suggest you to add your mail to the CC list to be automatically notified when an update arrives.
