problems with chart
Friis
problems with chart
Post by Friis » Thu Sep 10, 2015 7:53 pm
I'm having problems with the following code. It gives me the error "...EListError with message 'List index out of bounds (-1)'
I'm using TeeChart Pro 2013.09.131110 32 Bit VCL
1) it seems that disabling chart1.leftaxis.setminmax solves the problems but if I really need to setminmax...
2) If you disable chart1.leftaxis.setminmax, the problems disapperas but reappears when trying to zoom
unit Unit1;
interface
uses
  Dialogs, ComCtrls, TeeGDIPlus, ExtCtrls, TeeProcs, TeEngine, Chart, Series;
type
  TForm1 = class(TForm)
    PageControl1: TPageControl;
    TabSheet1: TTabSheet;
    TabSheet2: TTabSheet;
    Chart1: TChart;
    Series1: THorizBarSeries;
    Procedure MakeLegendChart2;
    Procedure InitializeChart(const XChart:TChart);
    procedure FormShow(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.FormShow(Sender: TObject);
InitializeChart(Chart1);
MakeLegendChart2;
Chart1.leftaxis.Title.Caption := 'Production Order Number';
Chart1.BottomAxis.Title.Caption := 'Number of Profiles';
Chart1.Title.Clear;
Chart1.Title.Text.Add('Production Order Number vs. Number of Profiles');
Chart1.Legend.Alignment := laBottom;
with Chart1.AddSeries(THorizBarSeries.Create(self)) as THorizBarSeries do
    ParentChart := Chart1;
    Title := 'Number of Profiles to be Produced';
    ShowInLegend := False;
    shadow.Visible := false;
    XValues.DateTime := false;
    Marks.Style := smsValue;
    Marks.Shadow.Visible := false;
    brush.Style := bsSolid;
    StackGroup := 2;
    Marks.Clip := true;
    Title := 'Number of Profiles Already Produced';
    ShowInLegend := false;
    brush.Style := bsDiagCross;
    seriescolor := clBlack;
    StackGroup := 1;
    Marks.Clip := true;
with Chart1[Chart1.SeriesCount -2] as THorizBarSeries do
  addxy(420,0,'P04567',clred);
  addxy(210,1,'P04566',cllime);
chart1.LeftAxis.SetMinMax(-1,2);
Procedure TForm1.InitializeChart(const XChart:TChart);
with XChart do
Color := clwhite;
Gradient.Visible := false;
BackWall.Color := clWhite;
BackWall.Gradient.Visible := false;
View3D := false;
BevelOuter := BvNone;
FreeAllSeries();
RemoveAllSeries;
Title.Text.Clear;
Legend.Shadow.Visible := false;
legend.Font.Size := 14;
legend.Symbol.Width := 50;
legend.Symbol.Squared := true;
Procedure TForm1.MakeLegendChart2;
Chart1.Legend.Visible := true;
Chart1.Legend.LegendStyle := lsSeries;
    Title := 'ItemNumber 040059';
    ShowInLegend := true;
    seriescolor := clred;
    StackGroup := 0;
    MultiBar := mbStacked;
    with Chart1[Chart1.SeriesCount-1] as THorizBarSeries do
        addxy(1,-2,'',clred);
    Title := 'ItemNumber 040170';
    seriescolor := clAQUA;
    StackGroup := 0;
        addxy(1,-2,'',clAQUA);
    Title := 'ItemNumber 040190';
    seriescolor := clLIME;
    StackGroup := 0;
        addxy(1,-2,'',clLIME);
    Title := 'ItemNumber 040198';
    seriescolor := clFuchsia;
    StackGroup := 0;
        addxy(1,-2,'',clFuchsia);
    Title := 'ItemNumber 040211';
    seriescolor := clGray;
    StackGroup := 0;
        addxy(1,-2,'',clGray);
    Title := 'ItemNumber 040193';
    seriescolor := clBlue;
    StackGroup := 0;
        addxy(1,-2,'',clBlue);
    Title := 'ItemNumber 040182';
    seriescolor := clPurple;
    StackGroup := 0;
        addxy(1,-2,'',clPurple);
    Title := 'Amount Produced';
    StackGroup := 0;
        addxy(1,-2,'',clBlack);
end.
Re: problems with chart
Post by Yeray » Mon Sep 14, 2015 10:48 am
I could reproduce the error with your code and TeeChart v2013.09 and v2014.10 but not with v2014.11 and neither with the actual version v2015.16.
So I'd suggest you to upgrade to the latest version.
