Adjusting line height of TRectagleTool
jens.mertelmeyer
Post by jens.mertelmeyer » Wed Sep 02, 2015 3:36 pm
Hi there.
Please have a look at the following image:
On the left you see a normal TMemo straight from the VCL.
On the right, we have a TeeChart with a TRectangleTool on it. By themselves, they both look fine.
However, I am puzzled about the different line height of the TRectangleTool. There is more space between the lines. Is there a way to adjust the "line spacing"? I have found no way.
Many thanks in advance.
Re: Adjusting line height of TRectagleTool
Post by Yeray » Fri Sep 04, 2015 12:53 pm
Can you please attach here that simple test project?
jens.mertelmeyer
Post by jens.mertelmeyer » Fri Sep 04, 2015 3:49 pm
Sure. There's not much magic involved:
procedure TForm3.createTool();
	textRectangle := TRectangleTool.Create(Chart);
	textRectangle.ParentChart := Chart;
	textRectangle.Shape.Font.Assign(Font);
	textRectangle.Shape.Font.Color := TColors.Black; // I have no clue why this is necessary
	textRectangle.Text := Memo1.Lines.Text;
	textRectangle.Bounds := textRectangle.ParentChart.ClientRect;
	textRectangle.Shape.Transparency := 0;
	Chart.Tools.Add(textRectangle);
TextRectangleTool.zip
(5.14 KiB) Downloaded 1001 times
Post by Yeray » Mon Sep 07, 2015 10:49 am
Thanks for sharing the test project.
This is because TeeChart uses GDIPlus by default since a few releases ago and different techniques are used to calculate the TextHeight.
Adding this to your test project gives a more similar result at both sides:
type
  TCanvasAccess=class(TTeeCanvas3D);
  Chart.Canvas:=TTeeCanvas3D.Create;
  TCanvasAccess(Chart.Canvas).FontQuality:=fqClearType;
jens.mertelmeyer
Post by jens.mertelmeyer » Mon Sep 07, 2015 10:56 am
Yes, they're almost identical now. Thank you.
It still has a pretty different ... padding compared to a TMemo but I think I can sort that out. Thanks again.
