Set Axis Label Value Format
amol
Post by amol » Thu Aug 27, 2015 10:13 am
Hi Steema Support,
We want to set axis Label Value format using code:- tchart1.Axes.Bottom.Labels.ValueFormat ="#.000E+0";
but it does not show any changes or work expected. We are attaching demo for the same.
ManageAxis.rar
Demo file for Set Axis Label Value Format
(56.61 KiB) Downloaded 1049 times
PlanoResearch
Re: Set Axis Label Value Format
Post by Narcís » Thu Aug 27, 2015 10:40 am
Hi PlanoResearch,
That's because you are using custom axis labels and you are not setting custom axis labels strings to this desired format, you should set the desired string format in the Double.ToString method, for example:
      tChart1.Axes.Bottom.Labels.Items.Clear();
      tChart1.Axes.Bottom.Labels.Items.Add(tChart1.Axes.Bottom.Minimum, tChart1.Axes.Bottom.Minimum.ToString("###0.00"));
      double incrBottom = tChart1.Axes.Bottom.Increment;
      double labelvalueBottom = tChart1.Axes.Bottom.Minimum + incrBottom; //increment in steps of 500
      while ((labelvalueBottom) <= tChart1.Axes.Bottom.Maximum)//tChart1.Axes.Bottom.Minimum ++ incr
        tChart1.Axes.Bottom.Labels.Items.Add(labelvalueBottom, labelvalueBottom.ToString("###0.00"));
        labelvalueBottom += incrBottom;
amol
Post by amol » Fri Aug 28, 2015 12:33 pm
Thanks! Steema Support it works successfully!!!
