Class Not Found on LoadChartFromFile
Roland
Post by Roland » Fri Jul 24, 2015 7:35 am
Hi.
I save a chart that contans series added at runtime via SaveChartToFile.
When I load the chart via LoadChartFromFile on the next programstrat I receive a "TFastLineSeries class not found error".
I thought the problem might be caused by not linking with runtime packages, but still could not handle to get it running by using runtime packages. If missing runtime packages might cause the issue, which package would I need to link into my appluication? What else could cause this problem?
Best regards
Roland
Re: Class Not Found on LoadChartFromFile
Post by Yeray » Fri Jul 24, 2015 9:54 am
Try registering the series with:
uses Series;
  RegisterTeeStandardSeries;
Roland
Post by Roland » Fri Jul 24, 2015 3:56 pm
thanks a lot. That solves the problem.
Best regards
Roland
