There is simple example in attachment, which adds two color lines to the chart.
The color line that was added first can be smoothly moved, however color line that was added second moves very-very slowly. Also, at this time cursor flickers.
Please suggest what can I do to make them all move smoothly.
Color line is very slow
- TeeChartExample.zip
- (9.13 KiB) Downloaded 852 times
- Guru
Re: Color line is very slow
I'm afraid I can't reproduce this issue here with the latest publicly available version of TeeChart.dll. Here is a video of the behaviour on my machine:icecream wrote: The color line that was added first can be smoothly moved, however color line that was added second moves very-very slowly. Also, at this time cursor flickers.
http://screencast.com/t/J1FteXis
which version of TeeChart.dll are you using? Are you using a modern video card?
I am using version 3.5.3274.30664.
- Guru
Have you tried downloading the latest evaluation version from here:icecream wrote:I am using version 3.5.3274.30664.
http://steema.com/download/net
to see if that resolves the issue?
Latest version works fine.Christopher wrote:Have you tried downloading the latest evaluation version from here:
Support, is there a workaround for version 3.5?
- Guru
No, I'm afraid there isn't.icecream wrote:Support, is there a workaround for version 3.5?
I was able to fix the issue, but I do not understand why does this work. I have found an old project with color lines, which all move smoothly and step by step removed its parts until it stop working.
It is not clear why, but it works because of Steema.TeeChart.Tools.Annotation object placed on my UserControl. You can find it in the project with the name "annotationMaxLabel".
Also, the annotation configured in a very strange manner:
Please find example in attachment.
this.annotationMaxLabel.Shape.Shadow.Visible = true;
this.annotationMaxLabel.Shape.Top = -100;
this.annotationMaxLabel.Shape.Transparent = true;
this.annotationMaxLabel.Top = -100;
- (10.44 KiB) Downloaded 849 times
