addFastLine() does not repaint the chart.
iblee
Post by iblee » Thu May 28, 2015 2:17 am
I am upgrading tchart in my program from 8.0 to v2014.
In the program, I use fastline series to draw data received from my HW.
I works well in 8.0 but does not in 2014.
in 2014, series is not updated when I call AddRealTime().
I tested this and found that if I set setMinMax() to bottom axis, update does not work or rarely called.
I set Tchart as below
m_chart.ClearChart();
	m_chart.GetAspect().SetView3D(false);
	m_chart.AddSeries(scFastLine);
	m_chart.GetAxis().GetBottom().SetAutomatic(FALSE);
	m_chart.GetAxis().GetBottom().SetMaximum(10);
	m_chart.GetAxis().GetLeft().SetAutomatic(FALSE);
	m_chart.GetAxis().GetLeft().SetMinMax(-10, 10);
and call addRealTime in timer function
void CTChart2015TestDlg::OnTimer(UINT_PTR nIDEvent)
	// TODO: 여기에 메시지 처리기 코드를 추가 및/또는 기본값을 호출합니다.
	m_chart.Series(0).GetAsFastLine().AddRealTime(float(m_nCount)/30, sinf(float(m_nCount)), NULL, 0);
	//m_chart.Series(0).GetAsFastLine().
	m_nCount++;
	CDialogEx::OnTimer(nIDEvent);
How can I use fastline with axis.SetMinMax()?
Re: addFastLine() does not repaint the chart.
Post by Yeray » Fri May 29, 2015 9:15 am
The discussion here may put some light:
http://www.teechart.net/support/viewtop ... =1&t=13381
iblee
Post by iblee » Sat May 30, 2015 3:14 am
I already used fastline series without any problem in V8.0.
In 8.0, calling addRealTime drew new added data in chart. (not whole chart)
After I upgraded to v2014, the chart is only repainted when the data is out of axis range.
If the added data located inside of axis range, series does not paint newly added one.
iblee
Post by iblee » Sat May 30, 2015 12:28 pm
I tested fastline series with v8.0, v2012, v2014 and v2015. (2012 and 2015 was evaluation ver.)
The code tested was exactly same and only replaced tchart version.
I tried to test with v2013 evaluation version but threre is some missing header file(ThemesList.h)
The result is very interesting.
v8.0 and v2012 draws real time plotting without any problems but v2014 and v2015 does not repaint the data added with addRealTime().
Our company has v2014 license then could we use v2012?
My test code is hear.
Initialization.
m_chart.GetAspect().SetView3D(FALSE);
	m_chart.Series(0).GetXValues().SetOrder(loNone);
	m_chart.GetAxis().GetLeft().SetMinMax(-1,1);
	m_chart.GetAxis().GetBottom().SetMinMax(0, 10);
	m_nCount   = 0;
	this->SetTimer(0, 30, NULL);
In Timer
void Ctest2015Dlg::OnTimer(UINT_PTR nIDEvent)
	m_chart.Series(0).GetAsFastLine().AddRealTime(double(this->m_nCount)/30.0f, sinf(double(this->m_nCount)/30.0f*3.14), NULL, 0);
	m_nCount++;
Post by Yeray » Mon Jun 01, 2015 3:29 pm
I see this was broken in TeeChart ActiveX v2014.0.0.3 but still worked fine in v2014.0.0.2.
http://bugs.teechart.net/show_bug.cgi?id=1220
In the meanwhile, an actual license should give access to a previous version, so you should be able to try v2014.0.0.2.
