ROTATED BOTTOM AXIS LABELS INCORRECTLY POSITIONED
In TChart version 8.02 I rotated bottom axis labels and they looked correct as per attachment. In version 2013 they are not correctly placed as per second attachment. In version 2014, the same problem exists. Can you advise what I need to do to get the desired label placement?
- Incorrect Bottom Axis Labels
- TChart Ver 2013 Axis Labels Rotated Wrong.PNG (11.23 KiB) Viewed 8699 times
- Correct Bottom Axis Labels
- TChart Ver 8.02 Axis Labels Rotated Correct.PNG (14.4 KiB) Viewed 8692 times
Re: ROTATED BOTTOM AXIS LABELS INCORRECTLY POSITIONED
This is an issue we are already aware of as you can see here:
http://bugs.teechart.net/show_bug.cgi?id=947
Thanks Yeray, is there any chance this could be fixed in the next version? It is significant for us to have this in our next release. Rolling back to the early release of 2013 wont work for our code is there are GDI+ issues.
Is there a way to owner draw the bottom axis labels?
Excuse us for the delay here.
I'll increment the ticket priority.
Forgot to say here the ticket was closed the 30th April 2015 but the changes were applied on the sources the 11th March 2015, so the v2015.15 published the 20th April 2015 includes the fix.
