BackWall.Brush.Gradient.Colors
alanmcd
Post by alanmcd » Wed Nov 19, 2014 5:35 am
I've dropped a DBChart onto a form in Delphi7
I can configure it correctly at design time. But when I run it, I get an exception
DBChart1.BackWall.Brush.Gradient.Colors - Property Colors does not exist.
When I go to the colors property, the (TTeeGradientColors) ellipsis button does not open a dialog.
If I go to the main chart edit, I can set the colors. I've tried setting visible off and other colors but I still get this exception.
Can you advise what I must do?
I have installed Teechart Pro v2014.12.140923
The same error was present in v2013 so I upgraded but the error is still there.
thanks
Alan
alanmcd
Re: BackWall.Brush.Gradient.Colors
Post by alanmcd » Wed Nov 19, 2014 6:04 am
I've removed the DBChart and replaced wit - started again. Now I get Labels Format does not exist exception.
Alan
Post by Yeray » Wed Nov 19, 2014 8:20 am
Hello Alan,
Please, check the list of packages and the library paths (both at "Tools/Environment Options" and at "Project/Options") with no project loaded.
Then, try a new simple example project. This should work fine.
