QrChart.Chart.RefreshData is not compiling in 64 bits
GTI
Post by GTI » Wed Oct 22, 2014 10:19 pm
The same application that compiles and woks fine in 32 bits is no compiling in 64 bits. The cause is the line RefreshData. The error message is the next: "Undeclared identifier:'RefreshData'". If I commented this line the application compiles.
Any idea?
Re: QrChart.Chart.RefreshData is not compiling in 64 bits
Post by Yeray » Thu Oct 23, 2014 7:43 am
If you can reproduce the problem with a new simple project with just a QRChart in the form, please attach it here.
If you can only reproduce the problem in an old & more complex application, please simplify it to the minimum while still reproducing the problem, and attach it here.
Also please tell us what exact TeeChart, QuickReport and IDE versions are you using.
