RemoveSeries does not release memory allocated to series
jhameenniemi
Post by jhameenniemi » Wed Oct 01, 2014 7:44 am
RemoveSeries does not release the memory allocated to the removed series. Included is a test application which removes an old bar series from chart and creates a new bar series to chart every 100 ms using a timer. If you open up TaskManager in Windows you'll see that the private bytes allocated for the test application increases rapidly and never decreases i.e. memory is never released.
TeeTest.zip
(87.71 KiB) Downloaded 1108 times
Re: RemoveSeries does not release memory allocated to series
Post by Yeray » Wed Oct 01, 2014 2:47 pm
I've reproduced this and created a new ticket in the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=938
