How to determine if all axis labels are visible?
jens.mertelmeyer
Post by jens.mertelmeyer » Wed Sep 17, 2014 7:26 am
Imagine a series (Bar Series) with every item having a label. We can set something like "labels -> min separation" of an axis. That's pretty cool. Instead of overlapping Labels, some are getting hidden.
The label in the middle got hidden
I've increased the chart's width a bit and now all labels are visible
My question is: How can I find out whether all labels are still visible or if some got hidden?
Many thanks in advance :)
Re: How to determine if all axis labels are visible?
Post by Yeray » Thu Sep 18, 2014 8:53 am
Hi Jens,
You could check Chart1.Axes.Bottom.Items.Count as in the following example:
uses Series;
  Chart1.Align:=alClient;
  with Chart1.AddSeries(TBarSeries) do
    FillSampleValues(6);
    Labels[0]:='Uno';
    Labels[1]:='Dos';
    Labels[2]:='Tres';
    Labels[3]:='Cuatro';
    Labels[4]:='Cinco';
    Labels[5]:='Seis';
  TrackBar1.Max:=100;
  TrackBar1.Min:=0;
  TrackBar1.Position:=10;
  TrackBar1.Frequency:=10;
procedure TForm1.TrackBar1Change(Sender: TObject);
  Chart1.Axes.Bottom.LabelsSeparation:=TrackBar1.Position;
  Label1.Caption:='Separation: ' + IntToStr(TrackBar1.Position) + ' %';
  ShowMessage(IntToStr(Chart1.Axes.Bottom.Items.Count) + '/' + IntToStr(Chart1[0].Count) + ' labels drawn');
jens.mertelmeyer
Post by jens.mertelmeyer » Thu Sep 18, 2014 9:00 am
The Items of the Axis, of course!
Thank you very much for this elaborate example :mrgreen:
