Calendar Series - Time Table
Chartist
Post by Chartist » Fri Sep 12, 2014 2:18 pm
Steema offers a TCalendarSeries
Is there a way to plan not just the days, but the hours of each day as well?
If yes: how?
if not: is there an alternative?
Cheryll
Cheryll
Re: Calendar Series - Time Table
Post by Yeray » Mon Sep 15, 2014 10:12 am
Hello Cheryll,
Chartist wrote:Is there a way to plan not just the days, but the hours of each day as well?
I'm afraid not.
How were you thinking to display the hours?
Here it is a simple example showing an Annotation with some text when a concrete date is clicked:
uses TeeTools, DateUtils;
var annot1: TAnnotationTool;
  annot1:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
  annot1.Active:=false;
procedure TForm1.Series1Change(Sender: TCalendarSeries;
  var Value: TDateTime);
  if (Value=Today) then
    annot1.Active:=true;
    annot1.Text:='9:00 - First Task' + #13 + '10:00 - Second Task';
    annot1.Left:=Chart1.GetCursorPos.X;
    annot1.Top:=Chart1.GetCursorPos.Y;
  end
Chartist
Post by Chartist » Mon Sep 15, 2014 10:56 am
thank you so much!
I will take this as base for my idea.
Warm Regards,
Cheryll
Cheryll
