Axes / Minimum / Maximum - without error message
Chartist
Post by Chartist » Wed Sep 03, 2014 4:50 pm
I set the range of an axes like this:
Chart1.LeftAxis.Maximum:=aValue;
Chart1.LeftAxis.Minimum:=anotherValue;
That often I read an error-message like, "the max value must be more / less than the min value" or similar.
Exchanging those lines had other useless error-message problems.
As the next line of code would fix this, those error-messages are nothing but annoying.
All my workarounds NOT to see this error-messages were ugly in the sense of "under the line unnecessary code".
Wasn't there a line to set Minimum and Maximum together and do the error-check at the end?
I thought to have seen it once, but cannot find it any more.
Cheryll
Cheryll
Re: Axes / Minimum / Maximum - without error message
Post by Yeray » Thu Sep 04, 2014 12:01 pm
Hi Cheryll,
Chartist wrote:Wasn't there a line to set Minimum and Maximum together and do the error-check at the end?
Yes, SetMinMax() method:
Chart1.Axes.Left.setMinMax(anotherValue, aValue);
Chartist
Post by Chartist » Thu Sep 04, 2014 2:33 pm
thank you so much!
Cheryll
Cheryll
