Link series to the custom data source
vgromov
Post by vgromov » Thu Aug 28, 2014 6:47 pm
I wonder if there is a way to provide data for series from custom source, say, C++ vector?
I have data containers in my framework, which provide random point access, minimax calculation, etc.
So far, I have to copy data from containers to series XY lists, which is quite waste of memory and CPU.
If TChartSeries could invoke interface of some sort, to allow seamless data provision from any custom containers, it would be great.
I assume, LIveBindings may provide an abstraction needed, but its performance is unacceptably low.
Working with interfaced abstraction is preferable.
Re: Link series to the custom data source
Post by Yeray » Fri Aug 29, 2014 1:36 pm
You could try directly assigning the XValues and YValues arrays as in the Real-time Charting article here.
I'm not sure if this will fit your requirements, but I'm afraid I can't think on a more generic solution. Note the chart needs these arrays to be populated some way or another to be able to draw the series.
On the other hand, note the Narcís' approach for a related request at StackOverflow regarding TeeChart .NET.
