I'd like to draw waterfall series and allow the user to change rotation and elevation. Depending on rotation, elevation, zoom and Chart3DPercent corners of the chart may be positioned outside of the visible area. After every change of rotation, elevation and Chart3DPercent I'd like to zoom the chart in a way that it fits best into the visible area. How can I do that?
p.s. I'm using TeeChart 8.08.
3D Zoom Fit
Re: 3D Zoom Fit
Hi to2,
It's a little bit complicated but can be achieved using the "Protected Hack" with the TTeeCanvas3D class and the code below. Find also attached the complete project:
unit Unit1;
interface
uses
Dialogs, TeeGDIPlus, TeEngine, TeeComma, ExtCtrls, TeeProcs, Chart, TeCanvas;
type
TForm1 = class(TForm)
TeeCommander1: TTeeCommander;
Chart1: TChart;
procedure Chart1AfterDraw(Sender: TObject);
private
{ Private declarations }
Procedure RectangleWithZ(Const Rect:TRect; var FPoints: TFourPoints; Z:Integer);
public
{ Public declarations }
Form1: TForm1;
implementation
{$R *.dfm}
uses Series, TeeSurfa, TeeTools;
Chart1.AddSeries(TSurfaceSeries.Create(Self)).FillSampleValues();
Chart1.Chart3DPercent:=100;
Chart1.Aspect.Orthogonal:=False;
Chart1.Tools.Add(TRotateTool.Create(Self));
//(Chart1.Tools.Items[0] as TRotateTool).Pen.Visible:=True;
FourPoints : TFourPoints;
FourPointsZ : TFourPoints;
RectangleWithZ(Chart1.ChartRect, FourPoints, 0);
RectangleWithZ(Chart1.ChartRect, FourPointsZ, Chart1.Width3D);
if not PointInRect(Chart1.ChartBounds, FourPoints[0].X, FourPoints[0].Y) or
not PointInRect(Chart1.ChartBounds, FourPoints[1].X, FourPoints[1].Y) or
not PointInRect(Chart1.ChartBounds, FourPoints[2].X, FourPoints[2].Y) or
not PointInRect(Chart1.ChartBounds, FourPoints[3].X, FourPoints[3].Y) or
not PointInRect(Chart1.ChartBounds, FourPointsZ[0].X, FourPoints[0].Y) or
not PointInRect(Chart1.ChartBounds, FourPointsZ[1].X, FourPoints[1].Y) or
not PointInRect(Chart1.ChartBounds, FourPointsZ[2].X, FourPoints[2].Y) or
not PointInRect(Chart1.ChartBounds, FourPointsZ[3].X, FourPoints[3].Y) then
Chart1.Aspect.Zoom:=Chart1.Aspect.Zoom - 10;
type
TCanvas3DAccess=class(TTeeCanvas3D);
Procedure TForm1.RectangleWithZ(Const Rect:TRect; var FPoints: TFourPoints; Z:Integer);
With Rect, TCanvas3DAccess(Chart1.Canvas) do
Calc3DPoint(FPoints[0],Left,Top,Z);
Calc3DPoint(FPoints[1],Right,Top,Z);
Calc3DPoint(FPoints[2],Right,Bottom,Z);
Calc3DPoint(FPoints[3],Left,Bottom,Z);
end.
- RotateZoom.zip
- (2.8 KiB) Downloaded 496 times
Re: 3D Zoom Fit
Thank you very much, Narcís. While trying it I've realized, it is not that simple to do the Protected Hack in BCB. I wonder, if Calc3DPoint can be done by using other functions like Calculate3DPosition.can be achieved using the "Protected Hack"
Re: 3D Zoom Fit
-> FourPointsFromRect works.I wonder, if Calc3DPoint can be done by using other functions
