Bug with Chart Title Font color
johnnix
Post by johnnix » Sun Jul 13, 2014 8:57 am
If you drop a Chart into a form and change the title font color to clBtnFace it drawn as yellow (latest TeeChart, Delphi XE6).
Screenshot 2014-07-13 11.52.gif (17.73 KiB) Viewed 24907 times
Re: Bug with Chart Title Font color
Post by Yeray » Mon Jul 14, 2014 9:41 am
Hello
johnnix wrote:If you drop a Chart into a form and change the title font color to clBtnFace it drawn as yellow (latest TeeChart, Delphi XE6).
Take a look at the TeeChart 2013 What's New document.
It says:
Any color (pen, font, gradient, brush, etc) is now treated as a proper 32bit color with RGB and Alpha components.
The only limitation is pseudo-colors can’t be used (clBtnFace, clWindow, etc).
johnnix
Post by johnnix » Mon Jul 14, 2014 11:31 am
Ok, so since I need to custom draw the title how can I assign the same color as the background?
Post by Yeray » Mon Jul 14, 2014 11:59 am
johnnix wrote:Ok, so since I need to custom draw the title how can I assign the same color as the background?
I'm not sure to understand it. If you are making reference to something discussed in another thread, please kindly provide the link to that discussion.
Otherwise, please try to explain with more detail what are you trying to achieve.
johnnix
Post by johnnix » Mon Jul 14, 2014 4:34 pm
Hello Yeray,
If you look at the screenshot you see that I need set the color of the title to match the color of the background, since the background color is clBtnFace how can I assign this to the title?
Post by Yeray » Tue Jul 15, 2014 1:24 pm
This seems to work fine for me here:
  Chart1.Gradient.Visible:=false;
  Chart1.Walls.Back.Gradient.Visible:=false;
  Chart1.Title.Font.Size:=20;
  Chart1.Title.Font.Color:=Chart1.Color;
johnnix
Post by johnnix » Tue Nov 04, 2014 7:27 pm
Attached is a project file, the clWhite button works fine but the clBtnFace button turns the font color to yellow.
Project1.zip
(6.37 KiB) Downloaded 1605 times
Post by Yeray » Thu Nov 06, 2014 9:06 am
Unfortunately, the "A" in RBGA is used to identify the special colors in VCL (clNone, clDefault, clBtnFace,...) so it can't be used for the transparency.
However, you can convert these special colors to regular colors using ColorToRGB function:
Chart1.Color := ColorToRGB(clBtnFace);
johnnix
Post by johnnix » Thu Nov 06, 2014 5:48 pm
Hello Yeray,
That did the trick, thank you very much!
