Painting Problem?
Blair
Painting Problem?
Post by Blair » Fri Jun 20, 2014 4:25 pm
Why is series 3 painting in series 2 in the second part of the graph, while it is painting on the top in the first part of the graph? Shouldn't it be the top series for the whole graph.
test.zip
(3.27 KiB) Downloaded 604 times
Re: Painting Problem?
Post by Narcís » Mon Jun 23, 2014 9:12 am
Hi Blair,
The problem is Series3 has less points than Series1 and Series2. It should have the same number of points and same X values for stacking to work fine with all series. Series3 has a gap between 1st December 2013 until 15th December 2013. Adding data (zero values) for Series3 within this range, as shown in the code snippet below, solves the problem.
uses VCLTee.TeeStore;
  i: Integer;
  LoadChartfromFile(Chart1, 'g:\temp\test.tee');
  for i := 1 to 15 do
    Chart1[2].AddXY(EncodeDate(2013, 12, i), 0);
Blair
Post by Blair » Mon Jun 23, 2014 9:13 pm
Ugg any quick way to check/add all the dates in all the series?
Post by Yeray » Wed Jun 25, 2014 8:34 am
Hi Blair,
Yes, you can do a loop like here.
