Drawing on a Rose Chart
esbglenn
Post by esbglenn » Tue Jun 17, 2014 8:01 am
Is it possible to draw a "*" or some other character at a given angle and radius on a Rose Chart?
I seem to recall doing something like this many years ago (not with Rose but with a bar chart or pie chart) with TeeChart but I can't find where I did it.
Re: Drawing on a Rose Chart
Post by Yeray » Tue Jun 17, 2014 2:25 pm
Here you have a simple example about how to do this.
Note I've extracted the CalcXYPosition method from TPolarSeries class. You can probably simplify this method while still fitting your needs.
const
 TeePiStep:Double = Pi/180.0;
var Angle, Value: Double;
    X, Y: Integer;
    tmp, AxisXRadius, AxisYRadius: Integer;
  Angle:=40;
  Value:=500;
  tmp:=Series1.CirclePen.HalfWidth;
  AxisXRadius:=Series1.XRadius-tmp;
  AxisYRadius:=Series1.YRadius-tmp;
  CalcXYPosition(Series1, Angle, Value, AxisXRadius, Series1.GetHorizAxis, X, tmp);
  CalcXYPosition(Series1, Angle, Value, AxisYRadius, Series1.GetVertAxis, tmp, Y);
  Chart1.Canvas.Font.Color:=clRed;
  Chart1.Canvas.TextOut(X, Y, '*');
procedure TForm1.CalcXYPosition(const ASeries: TPolarSeries; const XValue, YValue: TChartValue;
  ARadius: Integer; Axis: TChartAxis; out X, Y: Integer);
  Function CalcLogRadius(const tmpDif:Double):Double;
  var IAxisLogSizeRange : Double;
      ILogMin           : Double;
      ILogMax           : Double;
    ILogMax:=ln(Axis.Maximum);
    if Axis.Minimum<=0 then
       ILogMin:=0
       ILogMin:=ln(Axis.Minimum);
    IAxisLogSizeRange:=ARadius/(ILogMax-ILogMin);
    if Axis.Inverted then
       result:=Round((ILogMax-ln(tmpDif))*IAxisLogSizeRange)
       result:=Round((ln(tmpDif)-ILogMin)*IAxisLogSizeRange);
var tmp       : Double;
    tmpDif    : Double;
    tmpAtEnd  : Boolean;
    tmpRadius : Double;
  With Axis do tmp:=Maximum-Minimum;
     tmpDif:=Axis.Maximum-YValue
     tmpDif:=YValue-Axis.Minimum;
  if Axis.Logarithmic then tmpAtEnd:=tmpDif<=0
                      else tmpAtEnd:=tmpDif<0;
  if (tmp=0) or tmpAtEnd then
    X:=ASeries.CircleXCenter;
    Y:=ASeries.CircleYCenter;
  end
       tmpRadius:=CalcLogRadius(tmpDif)
       tmpRadius:=tmpDif*ARadius/tmp;
    ASeries.AngleToPos(TeePiStep*XValue,tmpRadius,tmpRadius,X,Y);
esbglenn
Post by esbglenn » Tue Jun 17, 2014 3:04 pm
Many thanks - worked as needed once I adjusted for my own code :)
Now to sit down and examine what actually happens. Great support!
