How to draw a vertical plane like X=10 or Z=50 ?
niotronic
Post by niotronic » Fri Jun 13, 2014 9:42 am
I 'm looking for a way to draw a vertical plane for example X=10, Z=100 etc. with a TSurfaceSeries, but this seems to be impossible because TSurfaceSeries doesn't draw anything if I add multiple points with same x value and different y and z values:
The code below should draw a plane with the equation: X=50 in the y/z range 0..255
AddXYZ(50,255, 0);
AddXYZ(50, 0, 255);
AddXYZ(50, 0, 0);
AddXYZ(50, 255, 255);
..but it doesn't draw anything!
Is there a way to draw such a plane with minimal number of points to add using any other series-type ?
Klaus
Re: How to draw a vertical plane like X=10 or Z=50 ?
Post by Yeray » Fri Jun 13, 2014 2:26 pm
Hello Klaus,
The easiest way I can think on right now would be changing some of the 50 values for something else (like ie 50.01):
  with Series1 do
    IrregularGrid:=true;
    AddXYZ(50,255, 0);
    AddXYZ(50.01, 0, 255);
    AddXYZ(50.01, 0, 0);
