TeeChart Gallery exception
ulibru
Post by ulibru » Tue Mar 18, 2014 5:03 pm
Create a new project with TeeChart. Add a series. Select tab Gauges. Boom.
See picture
TeeChart 2014 Pro Source + XE4
Cheers
Uli
Re: TeeChart Gallery exception
Post by Yeray » Wed Mar 19, 2014 2:44 pm
Hi Uli,
ulibru wrote:TeeChart 2014 Pro Source + XE4
Are you using v2014.10.140220 Pro SourceCode version?
I can't reproduce it with v2014.10.140220 Pro binary for XE4, that should be identical.
ulibru
Post by ulibru » Wed Mar 19, 2014 2:49 pm
I use a source version which I have got by Narcís at March 13. It has solved other bugs
But I do not know if it has a different version number and where it is located.
Uli
Post by Narcís » Fri Mar 21, 2014 9:53 am
Hi Uli,
You can find out the version number by right-clicking on a TChart component at design-time. However, this may not be accurate with test versions. It's a VCL application in RAD Studio XE4?
Anyway, I'm not able to reproduce it here. I'm going to send you the latest sources so that you can check if it solves the problem at your end.
ulibru
Post by ulibru » Fri Mar 21, 2014 2:28 pm
Hello Narcís,
as the displayed version number is not changed with different test versions it does not really make sense to talk about.
Anyway the latest source has solved the exception problem.
Furthermore I recognize that Delphi VCL is now running much quicker. Also the compiler benefits from speed improvement.
So now I wonder what has caused the slow down before.
Cheers
Uli
Post by Narcís » Mon Mar 24, 2014 9:55 am
Hi Uli,
Thanks for your feedback.
ulibru wrote: Furthermore I recognize that Delphi VCL is now running much quicker. Also the compiler benefits from speed improvement.
Not sure on this. We would need to see some test case to be able to provide an answer. Some recent changes that might improve this are some gauge clipping and loops to draw ellipses being removed.
