GDI+ wong legend display
ulibru
Post by ulibru » Thu Feb 27, 2014 12:04 pm
With the new 2014 VCL Pro sourcecode version I get a wrong legend like this
Is there a solution for GDI+ ?
Switching to GDI gives a correct display.
Best regards
Uli (XE4)
Re: GDI+ wong legend display
Post by Narcís » Fri Feb 28, 2014 11:17 am
Hi Uli,
I'm not able to reproduce it neither using a VCL application nor a FMX application. Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
Steve
Post by Steve » Thu Sep 08, 2016 1:29 pm
Hallo,
I use the TeeChart Pro v2015.16.150901 32bit VCL with D2007 and have the same problem. This happens only if the AntiAliasText is set to gpfNormal. Also i have a problem when i want to print the chart.
charttestdyn.zip
This example creates a chart and at the bottom three buttons. The first button Changes the AntiAliasText of the TeeGDIPlus-Componenten from gpfDefault to gpfNormal. The second button toggles the GDI+Active. The third one prints the chart.
(505.21 KiB) Downloaded 936 times
Post by Yeray » Fri Sep 09, 2016 10:43 am
I see the legend checkboxes are drawn displaced to the top when AntiAliasText is set to gpfNormal in GDIPlus, so I've updated the ticket and the test project in it:
http://bugs.teechart.net/show_bug.cgi?id=1430
In the meanwhile, you can use gpfBest, gpfDefault or gpfClearType that seem t work fine.
Steve
Post by Steve » Fri Sep 09, 2016 10:49 am
can you also comprehend the problem with the printing?
Post by Yeray » Mon Sep 12, 2016 10:15 am
Steve wrote:can you also comprehend the problem with the printing?
You are right. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1628
