After I run TeeRecompile.exe (as admin) there is a folder Compiled\Delphi19.iOSDevice\Lib. Inside the folder are a lot of *.o files and a few *.dcu files. When I try to run an application with a TChart I get errors saying that FMXTee.Engine could not be found. In Delphi the library is setup to point to the Compiled\Delphi19.iOSDevice\Lib folder. Also, TeeRecompile said it completed with no errors, but it took 3 minutes.
Although TeeRecompile said it had no problems, there are only 4 .dcu files: FMXTee.Bind.Chart.dcu, FMXTee.Bind.DBLinks.dcu, FMXTee.Bind.Editors.dcu, and FMXTeeChartPro.dcu. All the others files only have .o files. Any ideas why the .dcu files would be missing?
(I've included the TeeRecompile log just in case it's helpful:)
TeeChart Pro
Compilation started: 2/21/2014 1:44:08 PM
iOS Device v19 Enterprise (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 2s
Compiling... unit
Embarcadero Delphi Next Generation for iPhone compiler version 26.0
Copyright (c) 1983,2013 Embarcadero Technologies, Inc.
FMXTee.Editor.Series.ErrorBar.pas(43) Hint: H2219 Private symbol 'ChangedPen' declared but never used
376708 lines, 160.28 seconds.
Binding Units
74079 lines, 12.89 seconds.
TeeChart Installation
VERSION: 2013
Installing...
iOS Device v19 Enterprise (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 2m 55s
Total time: 175595 msec.
