Pie Chart containing zero value slices corrupts the display
Brian Nuvu
Post by Brian Nuvu » Thu Jan 02, 2014 2:12 am
Am running 2013 Pro VCL.
Can replicate this by simply dropping a TChart component on the form, and use the Chart Editor. Select 'Data', and then change some of the values to zero - you will see the pie (3D) display is corrupt (edges).
If I could just add a legend for the zero value without drawing the empty slice that would be fine.
This behavior only happends on 2013 - my preview 2012 version is fine.
Brian NuVu
Re: Pie Chart containing zero value slices corrupts the display
Post by Yeray » Fri Jan 03, 2014 9:27 am
Hi Brian,
I've added this to the bug tracking system:
http://bugs.teechart.net/show_bug.cgi?id=526
