TChart can't be cloned with Clone() Function?
The exception shows that "The TChart class can't be found"..
Re: TChart can't be cloned with Clone() Function?
Hi elmec,
Are you adding FMXTee.Chart unit to your project's uses section? Code below works fine for me.
If the problem persists please attach a simple example project we can run "as-is" to reproduce the problem here.
uses
FMXTee.Chart;
var Chart1,Chart2: TChart;
Chart1:=TChart.Create(Self);
Chart2:=(Chart1.Clone(Self) as TChart);
The example project.
- CopyChart.zip
- (74.6 KiB) Downloaded 599 times
Hi elmec,
C++ Builder needs to call RegisterClass befor calling Clone:
If there were series on tha chart you should also use:
void __fastcall TForm12::btnCopyClick(TObject *Sender)
RegisterClass(__classid(TChart));
TChart* chartcopyed = (TChart*)(Chart1->Clone(Chart1));
chartcopyed->Parent = this;
chartcopyed->Align = TAlignLayout::alClient;
#pragma link "FMXTee.Series"
RegisterTeeStandardSeries();
After the follow code added,
The TChart gets to OK, but the series still failed to be cloned.
- CopyChart.zip
- (81.7 KiB) Downloaded 655 times
Hi elmec,
Actually series are being cloned. What is not cloned is their data. You should manually do that using AssignValues:
TChart* chartcopyed = (TChart*)(Chart1->Clone(this));
for (int i = 0; i < Chart1->SeriesCount(); i++) {
chartcopyed->Series[i]->AssignValues(Chart1->Series[i]);
//Code to clone series
//CloneChartSeries(Chart1->Series)->ParentChart=chartcopyed;
Hello Narcís ,
It works!
Thank you so much!
BTW, is it a bug or just Tchart's behavior?
It works!
Thank you so much!
Hi elmec,
You're welcome.elmec wrote:Hello Narcís ,
It works!
Thank you so much!
This is as designed.elmec wrote:Hello Narcís ,
