I'm using the TeeChart Pro 2013, with Delphi XE2 since last week.
I opened an application after installing TeeChart and I got a badquality image, compared wiht the old ones. What should I do? I'm attaching both the new (and bad image) and the old (with good image)
Tks for you help
David Gurevitz
dbChart with bad quality image
- Good Lines Graphi.jpg (25.61 KiB) Viewed 2813 times
- Bad Lines Graphic.jpg (24.87 KiB) Viewed 2803 times
Re: dbChart with bad quality image
The last version moved the default canvas to GDIPlus. You can go back to the regular GDI Canvas anytime:
http://www.teechart.net/support/viewtop ... 454#p62454
