Annotation String Position
lilo
Post by lilo » Mon Sep 16, 2013 6:41 am
I need to center the string on an annotation horizontally. If I use AnnotationChart.Shape.TextAlign = StringAlignment.Center, the string should be centered horizontally? However, I can only get it positioned in the left near position?
Re: Annotation String Position
Post by Sandra » Mon Sep 16, 2013 9:52 am
Hello lilo,
If you use the Annotation tool property TextAlign and choose Center option, the text is Centered in the center of the Annotation tool, if you choose near option, it is aligned to left bound of rectangle and if you choose far option, the text is aligned to right bound of rectangle. See next code to check it:
    Steema.TeeChart.TChart tChart1;
      tChart1 = new TChart();
      this.Controls.Add(tChart1);
     // tChart1.Dock = DockStyle.Fill;
      tChart1.Top = 150;
      tChart1.Left = 100;
      tChart1.Height = 400;
      tChart1.Width = 550;
      Steema.TeeChart.Styles.Bar bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
      Steema.TeeChart.Tools.Annotation an = new Steema.TeeChart.Tools.Annotation(tChart1.Chart);
      bar1.FillSampleValues();
      an.Text = " Steema Software";
      an.TextAlign = StringAlignment.Center;
      button1.Click += button1_Click;
      checkBox1.Checked = true;
      checkBox2.Checked = false;
      checkBox3.Checked = false;
      checkBox1.CheckedChanged += checkBox1_CheckedChanged;
      checkBox2.CheckedChanged += checkBox2_CheckedChanged;
      checkBox3.CheckedChanged += checkBox3_CheckedChanged;
    void checkBox3_CheckedChanged(object sender, EventArgs e)
      Steema.TeeChart.Tools.Annotation tool = (tChart1.Tools[0] as Steema.TeeChart.Tools.Annotation);
      if (checkBox3.Checked)
        tool.TextAlign = StringAlignment.Far;
        checkBox1.Checked = false;
    void checkBox2_CheckedChanged(object sender, EventArgs e)
      if (checkBox2.Checked)
        tool.TextAlign = StringAlignment.Near;
    void checkBox1_CheckedChanged(object sender, EventArgs e)
      if (checkBox1.Checked)
        tool.TextAlign = StringAlignment.Center;
    void button1_Click(object sender, EventArgs e)
      tChart1.ShowEditor();
Please, could you check my code and tell us if it works in your end? If you consider it doesn't work properly for you, could you please tell us why?
lilo
Post by lilo » Mon Sep 16, 2013 10:12 am
Hi Sandra,
Thanks, it does work correctly...my problem was I did not set the annotation.width property correctly.
lilo
Post by Sandra » Mon Sep 16, 2013 10:21 am
Hello lilo,
I am glad your problem solved. :D
lilo
Post by lilo » Mon Sep 16, 2013 12:26 pm
Hi Sandra,
I struck another problem, the centering works fine for a text string with two characters or more, but does not work with one character. How can I center one character?
Post by Sandra » Tue Sep 17, 2013 9:43 am
Hello lilo,
I have changed the Annotation Tools string Steema Software to A and it is centered correctly, you can check it in my attached project. If in my project your problem doesn't occurs, but in your project the problem appears, could you please send us your project and tell us which version are you using, because can suggest you a good solution?
TestVS2012.zip
(10.61 KiB) Downloaded 1143 times
lilo
Post by lilo » Thu Sep 19, 2013 9:09 am
Thanks Sandra,
I can't open your project, as I am still using Visual Studio 2010...I might have to download an express version. In the meantime, I am able to workaround the problem by setting the annotation width and height manually to the character width and height.
Post by Sandra » Fri Sep 20, 2013 11:06 am
Hello lilo,
I have modified my project, because you can use it in VS2010. Could you test my attached project?
TestVisualStudio2010.zip
(11.13 KiB) Downloaded 1200 times
lilo
Post by lilo » Fri Sep 27, 2013 8:40 am
Hi Sandra,
Thanks, your project works fine. My project(s) will not work. I am using Visual Basic Net 2010 TeeChart V 4.1.2012.1312.
I am creating the annotation tools at runtime without the edit window.
Private Sub TChart1_MouseDown(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles TChart1.MouseDown
NumText = NumText + 1
ReDim Preserve AnnotationChart(NumText)
AnnotationChart(NumText) = New Steema.TeeChart.Tools.RectangleTool(TChart1.Chart)
AnnotationChart(NumText).PositionUnits = Steema.TeeChart.PositionUnits.Pixels
AnnotationChart(NumText).Shape.TextAlign = StringAlignment.Center
AnnotationChart(NumText).AllowResize = True
AnnotationChart(NumText).AllowEdit = True
AnnotationChart(NumText).AllowDrag = True
AnnotationChart(NumText).AutoSize = True
AnnotationChart(NumText).ClipText = True
AnnotationChart(NumText).Shape.Transparent = True
AnnotationChart(NumText).Shape.Font.Color = FontColor
AnnotationChart(NumText).Shape.Font.Name = NewTextFont
AnnotationChart(NumText).Shape.Font.Size = NewTextSize
AnnotationChart(NumText).Shape.Font.Bold = NewTextBold
AnnotationChart(NumText).Shape.Font.Italic = NewTextItalic
AnnotationChart(NumText).Shape.Font.Underline = NewTextUnderline
AnnotationChart(NumText).Shape.CustomPosition = True
AnnotationChart(NumText).Text = SymbolType
AnnotationChart(NumText).EndEdit()
AnnotationChart(NumText).Left = e.X - (AnnotationChart(NumText).Width / 2)
AnnotationChart(NumText).Top = e.Y - (AnnotationChart(NumText).Bounds.Height / 2)
AnnotationChart(NumText).Shape.Visible = True
Post by Sandra » Fri Sep 27, 2013 3:38 pm
Hello lilo,
Could you please, send us your project because we can reproduce your problem here and try to find the issue and try to give you a solution?
lilo
Post by lilo » Sat Sep 28, 2013 3:44 am
Hi Sandra,
Attached is a project for visual studio 2010.
CenterAnnotationTest (2).zip
(178.72 KiB) Downloaded 1164 times
Post by Sandra » Mon Sep 30, 2013 9:50 am
Hello lilo,
I have found your problem. It seems appears when you access to the RectangleTool TextAlign property, using the Shape of this tool as do in next line of code:
In this point, you must know you can access to RectangleTool TextAlign property directly, without using shape. I have changed it in your code and the problem of align disappears. You can see the modification, in next lines of code:
    Private Sub TChart1_MouseDown(sender As Object, e As System.Windows.Forms.MouseEventArgs) Handles TChart1.MouseDown
        AnnotationChart(NumText).TextAlign = StringAlignment.Center
        'Change Shape.
        AnnotationChart(NumText).Shape.Pen.Visible = True
        AnnotationChart(NumText).Shape.Transparent = False 'True
        AnnotationChart(NumText).Shape.Font.Color = Color.Black
        AnnotationChart(NumText).Shape.Font.Name = "Arial" 'NewTextFont
        AnnotationChart(NumText).Shape.Font.Size = 26 'NewTextSize
        AnnotationChart(NumText).Shape.Font.Bold = False 'NewTextBold
        AnnotationChart(NumText).Shape.Font.Italic = False 'NewTextItalic
        AnnotationChart(NumText).Shape.Font.Underline = False 'NewTextUnderline
        AnnotationChart(NumText).Text = "+"
Could you tell us if previous code solve your problem?
lilo
Post by lilo » Thu Oct 03, 2013 12:33 am
Thanks Sandra,
This solved the problem.
