This error happens occasionally on a continuously (every minute) updating linear chart.
I'm using TeeChart test version 0722fg.
Have you any idea why it happens?
Thank you!
Ishan.
java.lang.NullPointerException
at com.steema.teechart.axis.Axis.internalCalcLabelStyle(Axis.java:2042)
at com.steema.teechart.axis.Axis.calcLabelStyle(Axis.java:3203)
at com.steema.teechart.axis.Axis.maxLabelsWidth(Axis.java:1484)
at com.steema.teechart.axis.Axis.internalCalcSize(Axis.java:1539)
at com.steema.teechart.axis.Axis.getSizeLabels(Axis.java:1577)
at com.steema.teechart.axis.Axis.calcRect(Axis.java:2459)
at com.steema.teechart.Chart.axisRect(Chart.java:2197)
at com.steema.teechart.Chart.calcAxisRect(Chart.java:2216)
at com.steema.teechart.Chart.internalDraw(Chart.java:722)
at com.steema.teechart.Chart.paint(Chart.java:2080)
at com.steema.teechart.TChart.image(TChart.java:1453)
at com.steema.teechart.Chart.image(Chart.java:291)
at com.steema.teechart.TChart.getImage(TChart.java:1060)
at com.steema.teechart.TChart.paint(TChart.java:482)
at com.steema.teechart.TChart.paintChart(TChart.java:509)
at com.steema.teechart.TChart.access$400(TChart.java:79)
at com.steema.teechart.TChart$2.paintControl(TChart.java:341)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:230)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4136)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Control.drawWidget(Control.java:1244)
at org.eclipse.swt.widgets.Widget.drawRect(Widget.java:741)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5473)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:4875)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5241)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSApplication.nextEventMatchingMask(NSApplication.java:94)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3615)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
