I'm not having much luck finding all the info on this subject.
Once I have entered text using TeePreviewPanel1.Canvas.TextOut TeePreviewPanel1.PaperRect....
I launch the Print Preview dialog. The graph shows up including in the correct position as where it was set in the TeePreviewPanel, however the PaperRect text is not visible, and doesn't print. So what am I doing wrong?
See attached test program.
Using:
Windows XP SP3
VB6 SP6
TeeChart Pro ActiveX Control v2013
Thanks!
Using TeeChart Print Preview & TeePreviewPanel
- TextPrintTest.Zip
- (2.65 KiB) Downloaded 992 times
Re: Using TeeChart Print Preview & TeePreviewPanel
The custom drawing should be done in the TeePreviewPanel's OnAfterDraw event.
However, I see it isn't available in the last versions. I've added it to the defect list to be revised asap (TA05016666).
In TeeChart ActiveX v8 I can do:
However, even with TeeChart ActiveX v8, I can't print the custom draws. I've added to the wish list the possibility to print the custom draws added in a TeePreviewPanel (TA05016670).
Dim footer, header As Boolean
Private Sub Form_Load()
TeePreviewPanel1.Chart = TChart1
TeePreviewPanel1.Orientation = ppoLandscape
footer = False
header = False
Private Sub mnuAddFooter_Click()
footer = True
TeePreviewPanel1.Repaint
Private Sub mnuAddHeader_Click()
header = True
Private Sub mnuPrint_Click()
TChart1.Printer.ShowPreview
Private Sub TeePreviewPanel1_OnAfterDraw()
If footer Then
With TeePreviewPanel1.Canvas
.Font.Color = vbBlue
.BackColor = vbWhite
.Font.Size = 12
.TextOut TeePreviewPanel1.PaperRect.Left + 10, _
TeePreviewPanel1.PaperRect.Top + 190, _
"Footer Text"
End With
End If
If header Then
.Font.Color = vbRed
.Font.Size = 12
TeePreviewPanel1.PaperRect.Top + 6, _
"Header Text"
End With
End If
Thanks for looking at this.
Do you have a release date for the corrections?
I'm afraid I can't tell you when this will be fixed/implemented.
Feel free to follow the following channels for new release announcements: this forum, RSS news feed, Twitter and Facebook
And check what's implemented on each new release looking at the public release notes:
https://www.steema.com/versioninfo/ax
