Blurred 3D chart - GDI+ and 3D series
StatusPro
Post by StatusPro » Thu Jun 20, 2013 1:22 pm
Dear all,
I've got a little problem with 3D charts and GDI+:
I use a TChart in 3D mode - a few Point3D series and 3-5 surface series.
If I turn on the GDI+ mode TTeeGDIPlus.Active and .Antialias the charts start blurring when it is moved by TRotateTool. (see the pictures attached)
If I click on the graph without moving - the blur reduces by each click. After more or less 10 clicks, the blur effect ist completely gone.
Any ideas on how to solve this ?
Delphi 7 - latest TChart 2013 Version
Thanks for any help in advance.
If clicking on the chart without moving, blur effect disappears
Picture from blurred chart after movement
Re: Blurred 3D chart - GDI+ and 3D series
Post by Narcís » Thu Jun 20, 2013 1:33 pm
Hi StatusPro,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
StatusPro
Post by StatusPro » Thu Jun 20, 2013 3:57 pm
Dear Narcis,
hope that simple example helps.
I had no time to add the "normal" Data amount. All the taper lines and multiple rings of data in 3D view.
With these it even blurrs more.
The demo does blur for me, too,
Best regards
Christian
BlurTest.zip
(3.92 KiB) Downloaded 380 times
Post by Narcís » Fri Jun 21, 2013 9:23 am
Dear Christian,
Thanks for the example project.
I started stripping it to the basics and finally found the problem is with TSurfaceSeries transparency. Disabling it in your project makes blur disappear:
var i: Integer;
  for i:=0 to ChartP.SeriesCount - 1 do
    if ChartP[i] is TSurfaceSeries then
      (ChartP[i] as TSurfaceSeries).Transparency:=0;
Then I found the minimal amount of code to reproduce the problem:
uses TeeSurfa, TeeTools, TeeGDIPlus;
var Series1: TSurfaceSeries;
  Series1:=TSurfaceSeries.Create(Self);
  Series1.FillSampleValues();
  Series1.Transparency:=50;
  Chart1.AddSeries(Series1);
  Chart1.Canvas:=TGDIPlusCanvas.Create;
  Chart1.Tools.Add(TRotateTool.Create(Self));
So I have added the issue (TV52016611) to the bug list to be fixed for future releases.
StatusPro
Post by StatusPro » Fri Jun 21, 2013 9:38 am
Thanks for the help Narcis.
Unfortunately I need the transparency enabled for the surface series.
I found a short workaround for that problem - but this is taking much CPU time on small UMPCs.
I use the "OnRotate" event of the RotateTool and set TeeGDIPlus.Active to "False" and directly after to "True" again.
This way blurring stops.
Please let me know, when the problem is finally gone.
Best regards
Christian
Post by Narcís » Fri Jun 21, 2013 10:11 am
Hi Christian,
Nice, thanks for sharing.
Please be aware at Steema Software communication channels for new release announcements and what's fixed on them.
