Locating ends of a DLine in Pixels.
tirby
Post by tirby » Wed May 29, 2013 5:24 pm
I've drawn a DrawLine on my graph, so now how do I find the ends in pixels?
I'm pretty sure this is easy, I'm just not seeing it...
Thanks!
Re: Locating ends of a DLine in Pixels.
Post by Yeray » Thu May 30, 2013 2:40 pm
Being ChartTool1 your TDrawLineTool, and being the line you want to check the one with index 0, the positions in axis values are:
ChartTool1.Lines[0].StartPos.X
ChartTool1.Lines[0].StartPos.Y
ChartTool1.Lines[0].EndPos.X
ChartTool1.Lines[0].EndPos.Y
Then, you should use the axes CalcPosValue function to transform axis values to pixels. Ie:
XStartPixel:=Chart1.Axes.Bottom.CalcPosValue(ChartTool1.Lines[0].StartPos.X);
YStartPixel:=Chart1.Axes.Left.CalcPosValue(ChartTool1.Lines[0].StartPos.Y);
tirby
Post by tirby » Mon Jun 03, 2013 3:58 pm
Thanks Yeray!
tirby
Post by tirby » Mon Jun 03, 2013 10:51 pm
Ok,
The above code does give me the info I need, however, it doesn't seem to give me the info I need when the Zoom function has been used.
When zooming in on an end of the DLine, the resulting view is expanded, but the CalcXPosValue(a) and CalcYPosValue(a) returns the same pixel value(s) as when the view is not Zoomed.
I can't figure out what parameter(s) are changed when the Zoom function is used.
Is there a "ZoomXFactor, ZoomYFactor" I can access?
Can you assist?
Thanks!
Post by Yeray » Tue Jun 04, 2013 9:59 am
Try forcing a chart repaint:
at the beginning of the OnZoom event. After it, the chart should have updated its internal values and the Calc* functions should work fine then.
tirby
Post by tirby » Tue Jun 04, 2013 2:55 pm
Thanks Yeray!
That solved the problem.
