ChartEdit Tools and Annotation
kjm
Post by kjm » Wed Apr 10, 2013 3:48 am
C++ XE3, TeeChart Pro v2012.07.121105
These are newly discovered problem, but not sure what version of C++ or TeeChart it happened.
First:
Create a new form, put TChart and TChartEditor on it. Run. Call the editor and the Tools option is missing.
Include VCLTee.TeeTools.hpp. No help.
add #pragma link "VCLTee.TeeTools" and the Tools tab appears.
Do I now need to add these manually when I include the ChartEditor?
Second problem, more important:
At run time, under Tools / Annotation there is no edit panel for entering or editing text. it is completely blank.
At design time, this feature works and annotations can be edited
Re-installed TeeChart. No help.
Is there a new setting that I am missing to enable Annotation editing?
My users need to edit annotations in the app at runtime.
Kevin
Re: ChartEdit Tools and Annotation
Post by Yeray » Wed Apr 10, 2013 2:56 pm
Hi Kevin,
kjm wrote:First:
Right. I think this happened also in TeeChart VCL v8. Are you sure it was different with any version?
kjm wrote:Second problem, more important:
Add this too:
#pragma link "VCLTee.TeeAnnToolEdit"
kmanuele
Post by kmanuele » Wed Apr 10, 2013 3:59 pm
Thanks for the quick response.
Apps and code from 2011 shows tools enabled and runtime annotation editing with none of those includes or pragma links, so they must have been automatic at one time.
Also, can you explain how to add more export options to TChartEditor at runtime? PDF, specifically.
Is there any support documentation on these topics? The help files are not much help
Thanks again
Post by Yeray » Thu Apr 11, 2013 8:02 am
kmanuele wrote:Apps and code from 2011 shows tools enabled and runtime annotation editing with none of those includes or pragma links, so they must have been automatic at one time.
It would be helpful if you could tell us what exact TeeChart version was the one that showed these tabs without needing to add the mentioned includes/pragma links.
kmanuele wrote:Also, can you explain how to add more export options to TChartEditor at runtime? PDF, specifically.
The exportation dialog to PDF is defined in TeePDFCanvas.
kmanuele wrote:Is there any support documentation on these topics? The help files are not much help
In the "Tutorial 12 - Exporting and Importing Charts" you can see the list of export formats and examples of some of them (JPEG, GIF, PNG).
In these examples it's indicated what unit you have to add to use them.
For the rest of export formats, you could click on them and navigate through the help to the unit where they are declared.
Also, being a source code customer, you could just search (ie for "pdf") in the TeeChart sources to know in what unit the exportation dialog to pdf is declared.
