Bar series patterns - line width
Jim Green
Post by Jim Green » Fri Mar 08, 2013 5:14 pm
I would like to have patterns, like Diagonal, with wider lines (they appear to be just one pixel?). E.g., like Excel's msoPatternWideDownwardDiagonal pattern fill.
Is this possible?
Jim Green
Re: Bar series patterns - line width
Post by Jim Green » Fri Mar 08, 2013 6:08 pm
OK, I created a 16x16 2-color bitmap from a screen capture of an Excel chart and set the BarBrush.Image to that file. Looks great!
However, when I print the patterns are indistinguishable (e.g., up vs. down diagonal). Any way to scale the line widths up for higher resolution targets?
Post by Yeray » Mon Mar 11, 2013 2:08 pm
Hello Jim,
Jim Green wrote:when I print the patterns are indistinguishable (e.g., up vs. down diagonal). Any way to scale the line widths up for higher resolution targets?
I don't understand what do you mean with the above. Could you please post an snapshot here? Or always better, could you please arrange a simple example project we can run as-is to reproduce the situation here?
Jim Green
Post by Jim Green » Mon Mar 11, 2013 2:52 pm
I mean that a 16x16 bitmap produces a distinctly visible pattern on a 96 DPI screen, but on a 600 DPI printer produces just a paler shade of the color. See the two attached PDF's. "PSP_PRINT" is a screen capture with the desired pattern. "Chart1" is the printed version - the pattern is so fine that you only see it when you zoom to about 800%.
SeriesPattern.zip
(17.83 KiB) Downloaded 686 times
Post by Yeray » Tue Mar 12, 2013 10:41 am
Hello Jim,
Have you tried to assign a bigger pattern when you are going to print the chart?
