Euro Symbol Is Incorrect for PDF
rgsolutions
Post by rgsolutions » Fri Feb 15, 2013 10:15 pm
If you have text in the chart that includes the euro symbol (€), the processing will replace it when you create pdf output. To recreate this problem, perform the following steps:
1. Create a new chart.
2. Change the title to include the euro symbol (i.e. Test€).
3. Export the chart.
4. Select Format as PDF.
5. Select Preview.
You will see that the euro symbol has been replaced with another symbol.
Re: Euro Symbol Is Incorrect for PDF
Post by Yeray » Mon Feb 18, 2013 9:02 am
What TeeChart version are you using?
Here with TeeChart v2012.07 and Delphi 7 I get this:
rgsolutions
Post by rgsolutions » Tue Feb 19, 2013 10:09 pm
I am using Build 2012.07.121105, RADXE2, and C++.
Post by Yeray » Thu Feb 21, 2013 4:51 pm
That's right, I could reproduce it with XE2. I've added it to the wish list to be revised for future releases.
In the meanwhile you could export your chart as an image and transform it to a pdf with a virtual printer.
