Java legend series color almost indistinguishable
pvasilev
Post by pvasilev » Tue Jan 29, 2013 7:39 pm
I noticed that when displaying 2D lines, in the legend the color of the lines is almost indistinguishable, very light. See the attachment from TeeChart Java 1.0 TeeChartFeatures.jar and TeeChartJava 3.2012.0808 (the same problem is present in 0202). Am I missing some setting to fix this?
The top window is TeeChart 1.0, the window in background is TeeChart 3.2012.0808
Re: Java legend series color almost indistinguishable
Post by Yeray » Fri Feb 01, 2013 12:13 pm
You are right, some change from v2 to v3 has broken this. I've added it to the defect list to be revised for next releases (TJ71016499).
Thanks for reporting it.
pvasilev
Post by pvasilev » Fri Feb 01, 2013 12:20 pm
Thanks Yeray,
I'm looking forward to see next maintenance release.
