Report Builder Compatibility
W3771M
Post by W3771M » Thu Jan 03, 2013 6:51 pm
After upgrading to the 2012 version of TeeChart the functionality of printing to ReportBuilder is not working anymore.
The source code in Report builder to paint a chart to a report (that does not work) is as follows:
   pmBitmap:
        lBitmap := TBitmap.Create;
        lBitmap.Height := spHeight;
        lBitmap.Width := spWidth;
        FChart.Draw(lBitmap.Canvas, lRect);
        lDrawCommand.Picture.Graphic := lBitmap;
        lBitmap.Free;
This, however, does.
lDrawCommand.Picture.Graphic := FChart.TeeCreateBitmap(clWhite,lRect);
Did you change the FChart.Draw() function from 2011 to 2012 version?
Do I need to specify anything else for the code to work?
Kind regards,
Willem Louw
Re: Report Builder Compatibility
Post by Yeray » Fri Jan 04, 2013 8:19 am
Hi Willem,
Using the following code, doing basically the same you posted but showing the bitmap in a TImage, works fine for me here out of Report Builder:
uses Series;
var lBitmap: TBitmap;
  Chart1.AddSeries(TBarSeries).FillSampleValues;
  Chart1.Draw;
  lBitmap.Height := Chart1.Height;
  lBitmap.Width := Chart1.Width;
  Chart1.Draw(lBitmap.Canvas, Chart1.ChartBounds);
  Image1.Picture.Bitmap:=lBitmap;
  lBitmap.Free;
I've just dropped a TChart and a TImage on the form at design time.
